Clone a polygon x times
  • Jun 2, 2017 3:11 AM UTC
  • 39 views
salvaleonrp
Forum|alt.badge.img+23
I have one polygon intersecting a pole. There are 2911 features on this pole feature class, there's only one polygon. After the pole feature class reader, I have a counter that counts the features, I want to use the max count of the counter to pass to the polygon cloner. See workspace below. My cloner number of copies is manually typed. I know I can use the statscalculator, but I'm looking for other options. The rest of the workspace - offsetting coor0 of each cloned polygon to a pole already works.
  • Jun 2, 2017 3:59 AM UTC
Hi @salvaleonrp, a possible way is to use a FeatureMerger (point -> Requestor, polygon -> Supplier) with these parameters.
  • Join On: 1 to 1 (unconditional merging)
  • Feature Merge Type: Attributes and Geometry
  • Accumulation Mode: Merge Supplier
  • Conflict Resolution: Use Supplier
There should be several ways. Hope someone posts other approaches to be discussed.
