Clip, zip and ship - without the 'zip' ?
  • May 29, 2013
  • 96 views
Hi!
I have a workspace producing one or two PDFs.
My customers are kind of no-IT-persons and they might not always be able to open zip-files. If possible I would like to append the output files as they are to the datadownload-email.
Is there a way to stop the zipping from taking place? Or any other workaround you suggest?
Best regards!
nic_ran
Forum|alt.badge.img+20
  • May 29, 2013
Which version of FME Server are you using?
Older versions of FME Server used to do the zipping as a post command at the end of the translation. This could be configured by editing the relevent subsection of the fmeEngineConfig.txt configuration file.
In newer versions of FME Server I believe the zipping is built right into the Data Download service so I don't think there's much you can do to change it.
If you can guarantee you will only be producing a single file from your workspace then you could think about using the Data Streaming service instead but it sounds like you might be producing multiple files?
  • June 7, 2013
Hi nic_ran!
Thanks for answering, I use 2013. Data streaming is a good idea, will definitly use that for complement.
The solution: (thanks to SWECO):
Catch the output directory/filname of the main writer and add a textwriter creating a .json file with that content:
"email_to" : "exemaple@abc.com" "email_attachment" : "C:/temp/p.pdf" } Then create a Topic and a subscription.
Publish workspace and register the "job submitter" as service on the topic.
