Clip Solids with TIN-Surfaces
  • January 19, 2016
  • 118 views
My problem is quite close to the one with the roof-models. But I want to get the whole building as a solid because I'm interested in it's volume.
I have a TIN for the ground and a TIN for the roof. For the walls I can extrude the polygon to a solid. Is it possible to cut back the solid to the two surfaces?
Or do I have a chance to get the volume between the two surfaces for each polygon without physically building up the model? As a result I need to add the volume as an attribute to a polyline, polygon or solid to identify to which building it refers.
Right now I only have access to 2014 Version
  • January 19, 2016
Here some data if anyone would like to test with it.
The link refers to a FTP-Server
http://pool.gossweiler.com/ftpVerm/Verm_mal_FME_test_N41xFzkKh6_16039.zip
Download before 08.02.2016
  • January 20, 2016
I think i can get to my result with CSGBuilder.. If I extrude my Polygons in positive and my Roof-Tin in negative Z direction i should be able to extract the Intersection between the two solids...
It's not running yet but could be the solution...
