Clip polygon with X m distance from vertex
  • Jul 27, 2021 10:05 AM UTC
  • 96 views
jugoslaviaa
I have 4 lines and I constructed a polygon by using AreaBuilding. Now, I would like to clip the polygon with a 60 m offset from the northeast point. How can I do it?
https://i.imgur.com/U59AcpG.png
Best answer by gazza
If you can extract that northwest line into a separate feature you can use the Bufferer to create a 60m buffer around it and use that polygon as the Clipper input in a Clipper transformer with the original polygon going into the Clippee input.
gazza
  • Jul 27, 2021 10:11 AM UTC
jugoslaviaa
  • Jul 27, 2021 10:14 AM UTC
Yes, i can. I dont know what I didn't think of it. Thx
