CityJSON WallSurfaces and RoofSurfaces
  • Jan 27, 2022 11:35 AM UTC
  • 159 views
Hi!
I have a question that I can't figure it out myself.
I have a CityJSON (v1.0.1.) building data set which contain surfaces with type both "RoofSurface", "WallSurface" and"GroundSurface". How can I read or filter my data based on these types? Does FME support this when processing CityJSON, like it does for CityGML?
I have tried eg. to extract geometry parts and deaggregate buildings, but none of these helped.
Thank you a lot!
Best answer by daveatsafe
Hi @alpoturunen​,
You can use the GeometryPartExtractor to extract the parts of the geometry where the geometry Name = WallSurface, RoofSurface, etc.
Screen Shot 2022-01-27 at 3.31.02 PMI am attaching a simple workspace to illustrate.
daveatsafe
Forum|alt.badge.img+24
  • Jan 27, 2022 11:35 PM UTC
Hi @alpoturunen​,
Hi @alpoturunen​,
Thank you! This solved the problem!
