Chop line from the beginning
  • June 4, 2017
  • 49 views
Dear All ,
We have a line with two vertices , we try to to shorten the line from the beginning to 10 meter using choper by length but not effect , Can someone help us archive this .
Thanks ,
Best answer by takashi
Hi @khalid_omer, consider using the Snipper rather than the Chopper.
  • June 4, 2017
mygis
Forum|alt.badge.img+14
  • June 5, 2017
Hi @khalid_omer
The chopper is used to convert your geometry into lines or points. As @takashi mentioned use the Snipper. However you need to check on the direction the lines were generated as well.
Thanks @takashi and @gisinnovationsb , it works great
