Change the order of output ports on a custom transformer
  • November 21, 2012
  • 133 views
jdh
Forum|alt.badge.img+41
Is there a way to change the order of output ports on a custom transformer?
  • November 22, 2012
I found the following way. - Display edit window of the custom transformer. - Once delete connection lines between transformer(s) and output ports. - Change the order (from top to bottom) of output ports in required order. - Re-connect transformer(s) and output ports.
gio
Forum|alt.badge.img+15
  • June 24, 2013
apart form disconnecting the ports u can also attach loggers ot the ports after u reshuffle the output order in the custom writer.
It resets the custom tranformer...
(downpart is ofcourse u have to remove the loggers afterwards)
But is usualy faster then disconnecting and reconnecting.
seems like an issue that should be adressed someday..
