Change Detection -
When I change Lenient geometry from Yes to No there areless elements coming out the Change Detector ports.  What does this mean?
lenient geometry matching means that the order of vertices in areas are ignored. So if some of your geometries have different vertex orders but are otherwise similar, it makes sense that this setting will influence the number of output features.
See also the documentation (http://docs.safe.com/fme/html/FME_Transformers/Default.htm#Transformers/changedetector.htm).
David
  • May 26, 2014
David,
Thanks, but I didn't state the issue correctly. What I meant to say is the total number of elements; added, deleted, unchanged, exiting the transformer is different when I select lenient geometry.  I would expect the number exiting each port to differ, but not the total.
Russell
Ah, I see. Thanks for clarifying.
Difficult to tell without knowing the data, though. I recommend you send some sample data and a minimal workspace to reproduce to either your reseller or Safe (https://safecommunity.force.com/knowledgeSubmitCase) for a more thorough anwer.
David
  • May 27, 2014
I'll get some data together and  "SubmitCase".
Thanks again,
Russell
