Cela est il possible de contourner des surfaces pour eviter la superposition ?
  • Oct 4, 2019 10:03 AM UTC
  • 70 views
Bonjour
Est il possible de realiser le contournement des surfaces comme montrer ci dessous avec FME ? Merci d'avance.
Forum|alt.badge.img+63
You can try a Bufferer and AnchoredSnapper (using the buffer as anchor)
jdh
Forum|alt.badge.img+41
  • Oct 4, 2019 3:20 PM UTC
Voici un petit prototype "preuve de concept"
perimeterdetour.fmw
mark2atsafe
Forum|alt.badge.img+59
Try the Displacer transformer. I think it is designed to handle cartographic overlaps.
jdh
  • Oct 4, 2019 4:30 PM UTC
What parameter settings would you use? The results I'm getting are a little odd. Playing with densifing the line, and the stiffness on the displacer.
