Case Insensitive Sort
  • August 25, 2017
  • 9 replies
  • 94 views
The Sorter does not appear to have an option for case-insensitive sort. Is it possible?
I am using FME Desktop 2016.1.3.1
Best answer by howard_l
Make a COPY of your original field (eg using AttributeManager).
Change case of data in new field to UpperCase.
Sort on this new UpperCase field.
Hope this helps
Howard L'
danilo_fme
Forum|alt.badge.img+57
  • August 25, 2017
Hi @jimo you can use BulkAttributeRenamer and choose lower or upper case.
Thanks
  • August 26, 2017
Hi @jimo, there is no option to perform case-insensitive sorting. As a workaround, consider uniforming all attribute values to one of UPPER CASE or lower case, with the StringCaseChanger, @UpperCase function or @LowerCase function.
  • August 26, 2017
Thanks
I know that you can use other transformers to make everything upper case or lower case and sort that way, but the problem is, this attribute represents a list of FMW scripts that will appear in a select box, and it is really important that the case of the FMW scripts remains true.
Is there a way to make the sort and keep the case of the values in the attribute?
  • August 26, 2017
Hope this helps
Howard L'
stalknecht
Forum|alt.badge.img+22
  • August 26, 2017
I think the NaturalSorter will give you the desired result.
  • August 26, 2017
Alternatively, the InilineQuerier with this SQL statement could also be used to sort the features in case-insensitive.
select * from my_table order by upper(key_attribute)
  • August 26, 2017
Hope this helps
Howard L'
I think this answer makes the most sense. Just another field, change the case in that field, then sort by that field.
Thanks
  • August 26, 2017
This attribute is coming from a csv file, though, not from a database.
  • August 26, 2017
No problem. The InlineQuerier works regardless of what the source format is. See the Help to learn more.
