Capturing Arrowhead Direction
  • January 24, 2014
  • 55 views
I'm doing a CAD to GIS  transformation of a telecommunication exchange and i'm looking to capture the arrowhead direction represented by the CAD arrows(they come across in FME as "autocad_block_name" ARROW), but when I filter them they come across as small line segments at the ends of the cable. In the end I need to be able to specify the number and location of arrowheads on a given piece of cable. If you have any ideas or need any additional information please let me know. Thanks.
-Tim
Best answer by david_r
If you need to find the angle of the line to rotate the arrow heads, the AzimuthCalculator (from the FME Store) might be of interest to you.
David
  • January 27, 2014
David
