Can Primavera and revit be integrated in GIS using FME?
  • Sep 3, 2018 12:43 AM UTC
  • 87 views
Can a revit model and a primavera schedule be integrated into GIS?
Forum|alt.badge.img+3
Hi @anayasm The short answer is yes. However, we used a script to export P6 to an SQL.
The biggest issue is ensuring the authors (modeller/planner) use consistent/structured coding for the appropriate elements.
The RVT to GIS bit also need a bit of thought, what components do you want to depict in GIS, I presume you mean 2D rather than 3D ????
