Can I show multiple outputs in the inspector?
  • July 30, 2014
  • 62 views
My workspace creates 3 Outputs for Polygons, Lines and Points. I want to inspect all 3 files at once in the inspector after I run the workspace. How can I achieve this without having to append the inspector 3 times?
Best answer by takashi
If you don't need write destination dataset when inspecting, check Workbench menu: Writers > Redirect to Inspection Application, and run.
  • July 30, 2014
