can ChangeDetector differentiate letter cases?
  • Jul 15, 2016 8:06 PM UTC
  • 86 views
I couldn't find any documents about this. So can anybody tell me if ChangeDetector can detect letter case different when comparing attributes. Thanks for your help!
erik_jan
Forum|alt.badge.img+26
  • Jul 15, 2016 8:14 PM UTC
ChangeDetector is case sensitive for attribute values.
See attached image:
  • Jul 15, 2016 8:56 PM UTC
See attached image:
Thanks for your quick response. Is there a way to compare attribute in case insensitive? otherwise, I have to convert to one case for comparison.
  • Jul 17, 2016 7:27 AM UTC
Hi @fmenewbie, if you want to compare attribute values in case-insensitive, change the case of all values to lowercase (or UPPERCASE) using the StringCaseChanger transformer.
  • Jul 17, 2016 1:31 PM UTC
thanks akashi for your response. I used AttributeCreator LowerCase string function and converted to a same case for comparison. your way deffinitely is gonna work.
