Calibrate an LRS with FME
  • November 27, 2012
  • 101 views
I would like to use FME to calibrate a regular street network for use as the basis of a linear referencing system.  Business rules are pretty simple: - routes should be built from constituent street segments without merging said segments - assume that valid routeID's already exist as an attribute in street segments - routes begin in cardinal south and end in cardinal north - routes begin in cardinal east and end in cardinal west - route measures are based on lengths of geometries composing the routes.   I recently created the results I want using Geomedia Pro with Geomedia Transportation Manager, but I would like to migrate to using FME so that the workflow is more easily reproducable.   Any resource that can help me get this done is appreciated.
Best answer by sigtill
This might be a first good read: http://spavicic.blogspot.no/2012/04/feature-manipulation-engine-linear.html
sigtill
Forum|alt.badge.img+25
  • November 28, 2012
