Calculation of IRI by integration for a colliding surface
  • Apr 11, 2024 1:11 PM UTC
  • 133 views
dallas2011
How to calculate the IRI between two points in FME if we know the distance and the slope?
Thank you.
crystalatsafe
Forum|alt.badge.img+32
Hi @dallas2011
I don’t believe there is a specific transformer that will calculate IRI.
If you know the formula however, you can use either the AttributeManager or AttributeCreator transformer to create a new attribute and enter the formula to set the value. This can be done by selecting the Arithmetic Editor from the Value column.
I hope this helps!
Crystal
dallas2011
  • Apr 16, 2024 5:08 AM UTC
Dear Crystal,
thanks your answer I appreciate it
Maybe you know the formula how to write into attribute creator?
thanks advice
crystalatsafe
Hi @dallas2011
I just want to confirm by IRI you mean the international roughness index?
While I don’t know the formula, this link might help https://community.esri.com/t5/water-resources-blog/terrain-ruggedness-index-tri-and-vector-ruggedness/ba-p/884340
In terms of writing the formula in the AttributeManager this link might help you out with setting up the Arithmetic Editor in the value column (under number 10).
https://support.safe.com/s/article/the-attributemanager-transformer
Crystal
