Calculating Hours As Percentage Of Day
  • Jan 30, 2020 3:52 PM UTC
  • 91 views
With the help of a number of posts on the forums, I've taken a large dataset and been able to evaluate the total time, within a range of days, pool cars have been used. What I'm now struggling with is to calculate the hours used as a percentage of a "working day"
eg;
Car One used for 04:20:00 hours, what percentage use is this against a working day of 07:00:00?
Do I need to calculate this out in seconds and convert back or is there another way?
Thank you.
erik_jan
Forum|alt.badge.img+26
  • Jan 30, 2020 4:13 PM UTC
I wrote out the calculation for you ( as I could not find a transformer to do so).
Was not too hard.
Hope this helps.
  • Jan 30, 2020 4:14 PM UTC
Pretty much whatever the solution, it would end up being converted to seconds somewhere along the way.
Try to create a new attribute with the following formula in the arithmetic editor (substituting "usage" and "workday" with your own attribute names of course):
@DateTimeParse("@Value(usage)",%H:%M:%S)*100.0/@DateTimeParse("@Value(workday)",%H:%M:%S)
With your example it returns 60.
  • Jan 30, 2020 4:31 PM UTC
@erik_jan & @david_r , thank you both for the replies. I did work through a solution after posting this morning, but will try both your answers. (I'm a complete FME newbie but love what it does).
I'm now looking at taking results from another dataset in order to add them to this data.
I shall post a grab of what I put together.
mark2atsafe
Forum|alt.badge.img+59
I put a solution in the Question of the Week thread.
Basically a DateTimeCalculator should do most of what you need by simply assuming the work day runs on 000000 to 070000:
