Calculate raster from multiple folder
  • Dec 28, 2018 3:06 AM UTC
  • 5 replies
  • 70 views
hoa_le
Hi all,
I have 3 folder 2016, 2017, 2018. Each folder have 46 images .TIF format.
In each folder, for one day have 3 images tif and split to _p1,_p2,_p3 and the date is same.
My goal sort images in each folder and execute raster calculate the first image of each folder to other first folder and then create folder based on squence 1,2,3....
I describe in here. Could you tell me how to the way make model ? Thank you
  • Dec 28, 2018 5:01 AM UTC
Does "(Ai+Bi+Ci)/3" in your screenshot describes that creating a single raster from the three rasters on the left hand side (e.g. 20160101_p1, 20170102_p1, and 20180101_p1) by calculating average value for each cell in those rasters?
How many bands does each raster have?
hoa_le
  • Dec 28, 2018 5:51 AM UTC
Yes. One band for each image
  • Dec 28, 2018 6:08 AM UTC
What about my first question?
hoa_le
  • Dec 28, 2018 6:17 AM UTC
yes. My question is the method to make it to receive the result like I describe.
In my mind, I think I will sort all file in folders and the next step I will make loop for the first image to n images in the folder and raster calculation. But I have not yet make it by this function?
  • Dec 28, 2018 10:42 AM UTC
If I understood the conditions and your requirement correctly, this workspace example might help you.
tiff2tiff-example.zip (FME 2018.1.0.3, including sample source dataset)
