Calculate parameterised value for all records into a field ?
  • Nov 13, 2019 9:26 AM UTC
  • 39 views
I'm sure the transformer is somewhere, but I simply cannot find a transformer that would accept
  • stream of features with attributes
  • value to calculate
..and it would calculate this value into the designated field.
Example: I have a statistic calculator that I need a _max value from. I want to feed this value to all the records in the stream into a field _max. I will then use the counter to assign the ids.
How can I achieve that?
Thank you
Forum|alt.badge.img+54
  • Nov 13, 2019 9:57 AM UTC
"I have a statistic calculator that I need a _max value from. I want to feed this value to all the records in the stream into a field _max. I will then use the counter to assign the ids."
Can you just not use the complete output port from the statistics calculator?
