Calculate measures on a specific point on a line
Dear FME community,
I have a line and a point dataset. The lines have measures, generated with the MeasureGenerator. Is there a way to extract these measures on a specific point? The points are in the other dataset.
For example: The blue line has the measures (1 per coordinate). The red point is another dataset which intersects the blue line. How can I access the measure at the location of the red point?
I can access the measures at the beginning of the line with the following settings (and save these in the attribute Netz_VST), but how can I tell him to use the point dataset?
Many thanks and best wishes
Thomas
  • August 3, 2016
Hi @thomask, the PointOnLineOverlayer will give measure to the input point based on the line measure (FME 2015.1+). You can then extract the measure from the output point using the MeasureExtractor (Type: Point).
  • August 3, 2016
Unfortunately, he does not show the measures:
The attribute _point_measure is empty:
Here the properties of the MeasureExtractor:
I'm using FME 2015.1.0.3 Build 15485 (32bit).
  • August 3, 2016
generally the PointOnLineOverlayer cannot overlay point on line with 0 tolerance, because there is unavoidable computational error. Try setting very slight amount as the tolerance. e.g. 1e-8 or so.
  • August 3, 2016
Thank you very much! It works perfectly :)
  • August 3, 2016
@takashi: One other question: at some entries (2 of 100) it shows the value -1.#IND for _point_measure. Do you have an idea what the cause could be?
  • August 3, 2016
I found out that it had something to do with the line geometries. 2 of them weren't valid according to the GeometryValidator. Now it seems to work.
