BulkAttributeRenamer doesn't work with Regex
  • Oct 7, 2020 11:29 AM UTC
  • 58 views
fikusas
Forum|alt.badge.img+5
I need from the left part (attribute name) get the right part.
Abcd.EfgT.OpKTs ----> OpKTs
When using BulkAtributeRenamer with this Regex, result is the same:
Action: Regular Expression Replace
Text to Find: (^[A-Z]{0,}\\.)([A-Z]{0,}\\.)([A-Z]{0,})
String: \\3
Best answer by ebygomm
The regex statement in the BulkAttributeRenamer is case sensitive, try
(^[A-Za-z]{0,}\.)([A-Za-z]{0,}\.)([A-Za-z]{0,})
In the above case, if I just wanted everything after the second full stop I'd use this to match the left part and replace with nothing
Forum|alt.badge.img+54
  • Oct 7, 2020 12:21 PM UTC
