Bulding a web interface for workbenchs:
  • February 5, 2014
  • 64 views
jhawks
Forum|alt.badge.img+7
We have a number of public extract/download workbenchs we'd like to build (better) webforms for. Currently the workflow I use is login to fme server, go to configure then select all and then paste the html into dreamweaver and then modify the webpage. There has to be a better way. Here are the web forms I've built:
http://fmeserver.ncd.noaa.gov/encdirect_extract_approach.html
http://fmeserver.ncd.noaa.gov/encdirect_extract_overview.html
I'd like to find a better way to do this so that if I make changes to the workbench I dont have to re dreamweaver snag the code and then manipulate it.
  • February 5, 2014
if I'm not mistaken, FME Server 2014 implements version 2 of the REST API which enables you to query FME Server about all the available workspaces and their published parameters.
Documentation here: http://docs.safe.com/fme/html/FME_REST/index.html#!/repositories/parameter_get_30
Based on this, you could write an application that (re-)generates your webforms based on these API calls.
David
  • February 5, 2014
Actually, this URL works better: http://docs.safe.com/fme/html/FME_REST/index.html#
David
fmelizard
Forum|alt.badge.img+22
  • July 7, 2014
fmelizard
  • August 4, 2014
