Bug / Issue - FMEServerJobWaiter
  • Jul 20, 2020 11:01 AM UTC
  • 67 views
An obvious issue that needs a warning.
If you have a single Server Engine and want to call a Workspace through FMEServerJobSubmitter. You cannot make use of FMEServerJobWaiter. It'll never complete as you only have a single engine.
Best answer by hollyatsafe
Hi @stevejames,
If you only have a single engine in the FMEServerJobSubmitter I'd recommend setting:
Submit Jobs: In Sequence
Wait for Jobs to Complete: Yes
This will launch an additional child engine to process these jobs meaning the parent job can wait until the child jobs submitted by the FMEServerJobSubmitter have finished before continuing to process features.
Once set, you'll see the output ports of the FSJS transformer changes from Submitted to Succeeded and Failed, allowing you to have different downstream responses depending on the result of the job.
In the Job History on FME Server you'll see the child has been run on the same Engine name but with the suffix @id where id is the Job ID of the Parent Job through which this additional engine was launched:
I have filed a request for our documentation team to include a warning in the FMEServerJobWaiter transformer Help that this transformer should not be used if your FME Server has one engine.
  • Jul 21, 2020 4:42 PM UTC
Hi @stevejames,
  • Jul 27, 2020 7:19 AM UTC
Brilliant @hollyatsafe that worked brilliantly.
