Bug in StringReplacer
  • November 18, 2016
  • 6 replies
  • 89 views
Good morning
I'm trying to replace some HTML code characters like (<) using Stringreplacer for a XML text. The strange thing is that not all characters are replaced. Few lines in the middle of the text kept the code character < (please check attached image below)
Any ideas ?
Thank you
  • November 18, 2016
I'm not sure I understand, "&lt;" isn't the same as "<" for the StringReplacer. Is that maybe the case here?
Forum|alt.badge.img+63
I'm with @david_r, if you use an Inspector before the StringReplacer, do you see "<" or "<"?
itay
Forum|alt.badge.img+19
  • November 18, 2016
Agree, try "&alt;" instead or in combination with "<"
  • November 21, 2016
Good morning everyone and thank you very much for your answers.
Using an inspector before the StringReplacer show this result:
Actually as I Said before the StringRepplacer did all the changes in the text except for some few lines.
Thank you very much
  • November 21, 2016
I changed the location of the StringReplacer and this time the result is very good. I have no more of these HTML code characters.
Thank you and best regards.
  • November 26, 2016
May be, use a python caller to search and replace all lines of HTML code.
