Bufferer management
  • Apr 18, 2018 3:24 PM UTC
  • 73 views
geo-x
Hi FME community.
I've difficulty to mange my Bufferer transformer.
In my case, I need to stop the buffer area to the Start and End point of my line, so I do this configuration (who works with 90% of my lines)
But with 10% I've this result and I need to have my lines in the area :
This is my test file :
Thank you for your help.
  • Apr 18, 2018 3:30 PM UTC
Just had a quick look using the latest FME 2018.0 and it seems buggy. I'd recommend sending the case to Safe support.
gio
Forum|alt.badge.img+15
  • Apr 18, 2018 3:57 PM UTC
or explode buff and merge
fmelizard
Forum|alt.badge.img+22
  • Apr 18, 2018 11:51 PM UTC
Hi @lalandexavier I agree that this looks buggy, but if you set the End Cap Style to Square or Round (the default) then the result should look as you expect.
geo-x
  • Apr 19, 2018 7:08 AM UTC
Ok Safe will be notified by Veremes society.
