Boundingbox length of sides attribute rounded?Is this a bug and if so, is it fixed in 2014
  • May 21, 2014
  • 0 replies
  • 30 views
gio
Forum|alt.badge.img+15
To rotate my maps in  a mapbookserie using ARcMap, i extract a angle using
oriented boundingboxes.
I use the option to use a attribute for the sides. It's an option in the transformer Boundingboxreplacer.
After chopping the boundingbox i use an expressionevaluator to test for
lenght of longest side = @Value(length). to acqurie angles of the longest sides.
Tester then said all failed???
So look at what fme does:
Up to four of the last digits appear different. Not one is the same. (only talking about those that should be the same angel of course.)
I assume that lenght() function is accurate. But what is up with the lengthcalculation of the BB-replacer.
And does this also occur in 2014 version?
This is in oriented mode BB_replacer mode, have not checked non-oriented.
( i now round the test to like 6 digits, its just for selection anyways)
