BoundingBox for DXF
  • Jan 17, 2020 12:57 PM UTC
  • 91 views
I have different DXF/DWG file and want to calculate the BoundingBox of the geometries for every file.
The BoundingBox should be a seperate layer in the output file.
What is the best way to solve my problem?
Thanks and best regards
lars_de_vries
Forum|alt.badge.img+10
The hard thing with DXF is that you'll have to rewrite the whole file.
Creating a Bounding Box of everything in the file can easliy be done with a BoundingBoxAccumulator, that transformer will create a bounding box of all input features.
The output layer can be defined in the Writer, so that shouldn't be too much of a problem.
What you can do as a small trick, is to only write the BoundingBox and to set the source DXF as a template file in the Writer parameters. There you also set both 'Preserve Model Space' and 'Preserve Paper Space' to "Yes". It is advisible (and maybe even necessary) to choose a different filename for the output.
I hope this will fix your problem.
