Boost NeighborFinder, is that possible?
  • Mar 11, 2022 9:21 AM UTC
  • 100 views
juanmahere
Forum|alt.badge.img+15
Hi all,
I'm having a bottle-neck on a workbench due to the use of the transformer "NeighborFinder". This operation only is taking around 18 hours.
The goal is to find around 200K points to the nearest Polygon (having around 10K). Points that I want are quite near, not touching some times. Also, there are some points that are farther and I don't want to have them on the "MatchedBase" output (red ones):
sample
These are the transformer parameters:
nf
Also, attributes from Polygon need to be transferred.
I don't see the option to make the search by Groups, since I cannot foresee which points belongs to certain Polygons beforehand. Also, reducing the number of features is not possible.
Any suggestion?
Something that could be faster on that search?
Thanks!
Juanma,
Best answer by redgeographics
Just throwing a random idea out there: what if instead of using the NeighborFinder you buffer the polygon slightly and then use a Clipper? It might be faster.
Forum|alt.badge.img+63
juanmahere
  • Mar 11, 2022 11:56 AM UTC
Hi @Hans van der Maarel​ ,
I was about to reply to myself with that solution. Thanks!
What I've done is to switch that NeighborFinder with a Buffer on Polygons (same amount as NFinder) and PointOnArea, after that a simple Tester to know what's inside:
imageIt is now taking just a few minutes!
Thanks for coming with that idea too, @Hans van der Maarel​ !
Juanma,
DanAtSafe
Forum|alt.badge.img+23
  • Mar 11, 2022 6:06 PM UTC
Hi @juanmahere​ Can you share your data and workspaces with us? It looks like we need to get the NeighborFinder to catch up to the PointOnAreaOverlayer! https://community.safe.com/s/submit-case Thanks!
