Bookmarks in FME 2014
  • January 20, 2014
  • 41 views
It looks like the default setting for bookmarks in FME 2014 is "unlocked", is that right? That is, when you draw a bookmark around transformers and move the bookmark, the transformers do not move. You have to "lock" the magnet in the top left corner.
That is the opposite from previous FME releases. Is there a setting where you can set the default? When I put a bookmark around some transformers, I usually want to move *** at some point. It is an extra step to have to lock the bookmark.
Thanks
Best answer by david_r
this is what I found:
If you right-click in the workspace and select "Insert bookmark", an empty bookmark with a deactivated magnet is created.
If you select more than one transformer, right-click one of the selected transformers and select "Insert bookmark", a bookmark surrounding the selected objects with an activated magnet is created.
Personally, I always use the latter method as I don't have to resize the bookmark myself that way...
David
  • January 20, 2014
David
