batch multiple by same prefix
  • October 3, 2015
  • 30 views
zzupljanin
Forum|alt.badge.img+5
Hello,
so, I have multiple TINs and multiple DBMs (as two readers) named by same nomenclature (multiple TINs and multiple DBMs). What I want is to batch each TIN with its DBM using prefix (which is the name of nomenclature). Is that even possible?
Thank you
pratap
Forum|alt.badge.img+12
  • October 6, 2015
Please correct me If I undertood your question wrongly...
1. By using published parameters you can do it.
2. I think, you will do in batch mode like 1 TIN & 1 DBM at a time
3. So place credentials of DBM & TIN as published parameters use the parameters in workspace
4. Use workspace runner transformer in another script with input of TIN and DBM credentials from xlsx or csv (1 TIN & DBM should be 1 record)
hope this will help
Pratap
