I have a shapefile from a GDB and I'm trying to remove extra fields that are null, blank, or just aren't needed to make the file size smaller and generally clean things up. I have my reader, the attribute remover, and the writer but when the translation is done and indicates it was successful, I open the new shapefile and all the fields that I wanted gone are still there. Am I missing an additional transformer or should I write it out as a GDB? This seems so simple but I can't get it to work!
Basic attribute removal
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
