Automatically Georeferencing PDF
  • Feb 5, 2020 3:13 PM UTC
  • 171 views
I use the RasterGeoreferencer with the Option all 4 Corner Coordinates to Georeference.
I export the map from ArcMap to PDF. The PDF has a part with Raster Data and a Part with Vector Data the same way as the Picture above. The Red Points are the Coordinates that i have (means i make a Bounding box and then a coordinate extractor list exploder) and after the RasterGeoreferencer the PDF has the shape of the Vector. Its squeezed together.
Is there a better way i can automatically georeference the pdf?
Can i export only the Vector Data from ArcMap?
Any idea's would be helpful.
owen
  • Feb 6, 2020 8:41 AM UTC
Hello. If you have the option to use ArcGIS Pro then you can choose to create a georeferenced pdf.
