AttributevalueMapper
  • September 4, 2014
  • 56 views
Hello,
How to use FindString function in AttributeValueMapper transformer.
I have an attribute _concatenated which concatenates geometry types in any dataset. I would like to map it on certain conditions.
e.g. if _concatenated = "fme_point" then map dest attribute to "POINT"
if _concatenated = "fme_point,fme_area" then map dest attribute to "POLYGON"
if _concatenated = "fme_point,fme_area,fme_no_geom" then map dest attribute to "POLYGON"
In short if _concatenated conatain string "fme_area" i would like to map it as POLYGON.
Is it possible to do this using string functions?
Cheers.
Best answer by takashi
I think it's easier to use the AttributeCreator with Conditional Value setting. For example:
Takashi
  • September 4, 2014
Takashi
