AttributeSplitter with no delimiter
I'm looking at splitting (text from the numbers) a column (source file is an .xls) into two seperate columns that have a format such as
1234A
12B
123456T
Their is no actual delimiter and the values varry in length, so I was wondering what the Format String parameters would look like in order to achieve this?
  • August 8, 2014
You can use the StringSearcher.
Regular expression examle:
^([0-9]+)([^0-9]+)$
Takashi
gio
Forum|alt.badge.img+15
  • August 12, 2014
AttributeSplitter with no delimiter results in a string being turned in a list, by character.
Can be handy for some further processig.
