Attributereprojector issue
  • Nov 19, 2020 8:09 AM UTC
  • 19 replies
  • 107 views
Dear community
I have just started using FME. I have an excel sheet with some x,y coordinates in the danish s34 (DenmarkS34-S) that i need to reproject into ETRS89 zone 32. I have tried using the attributereprojector but the coordinates i get are incorrect. I have also tried the csmapattributereprojector, but i cannot find that particular transformation.
I hope you can help.
Regards
Rasmus
Forum|alt.badge.img+63
Can you elaborate a bit? What values are you putting in, what are you expecting to get out of it and what is the actual output?
  • Nov 19, 2020 9:10 AM UTC
Yes. Right now I have just created a simple excel file with an x,y header and an x,y value of: 200000, 200000. A point in Jutland. I would expect to get: y: 6 232 728.28 m x: 595 254.05 m
But what i get is: y,x
3988202.0084898225,2825673.214985046
Are you sure the input coordinate values (or coordinate system) are correct? If I use a Creator to set a point at 200000,200000 in the DenmarkS34-S system the Data Inspector reports it as in the Mediterranean Sea, off the coast of Lebanon.
  • Nov 19, 2020 12:36 PM UTC
It should be correct, because that is how system34 is defined. I mean system34 is defined by this point in jutland with the coordinates 200000m, 200000m
Well, I tried this with all 4 DenmarkS34 systems available and none of them end up in Denmark... Hopefully somebody from Safe's support can chime in (I'm not Danish, so not familiar with Danish coordinate systems)
Forum|alt.badge.img+54
  • Nov 19, 2020 1:20 PM UTC
If you take your expected coordinate y: 6 232 728.28 m x: 595 254.05 m and transform it back to DenmarkS34-J (I've used Jylland rather than Sjælland as your point is there) you get
x:-200000.04766182226
y: 200000.05160261248
I don't know anything about this coordinate system to be able to say what the above proves however...
  • Nov 19, 2020 1:25 PM UTC
It is strange why it does not work the other way around then
  • Nov 19, 2020 1:33 PM UTC
It's not quite right, the x is minus 200000...
Your x-value is incorrect, if I put in -200000 instead of 200000 it does end up with a point in Denmark. Good catch by @ebygomm​
So if this is the case with all your Excel values multiplying that field by -1 should do the trick. You can do that with an AttributeManager or ExpressionEvaluator before the AttributeReprojector.
  • Nov 19, 2020 1:49 PM UTC
I wonder if it might be an error in the system, because this definition was used to ensure that there would be no negative coordinates in Denmark. But thanks for the answers, I shall try tomorrow and see if I can solve the problem by making x negative.
  • Nov 19, 2020 1:55 PM UTC
Yes, from what I've read, I wouldn't expect negative numbers in Denmark.
I don't think you can just times by -1, because then -300000 would be west of -200000 when presumably 300000 would be east of 200000?
  • Nov 19, 2020 2:08 PM UTC
Some more info
"For practical purposes, what is officially the X and Y axis in
this projection is switched to conform with other coordinate
systems, and the X axis is then counted as negative from its
origin East of Denmark, meaning that Agri has coordinates
(-200000, 200000) in my data. "
http://osgeo-org.1560.x6.nabble.com/Custom-projection-wildly-inaccurate-td3848728.html
  • Nov 19, 2020 3:40 PM UTC
Thanks for the answer and link. It is still hard for me to completely understand what I should do to make the reprojection.
Is it correct that i should make x=y and y=x and that i should multiply the x coordinates by - 1 before they are switched?
  • Nov 19, 2020 4:55 PM UTC
Do you have the Danish coordinates for any other known locations? I'd try and verify the logic by taking those coordinates and reprojecting to something you have background mapping for and seeing if they're in the right place
  • Nov 19, 2020 4:57 PM UTC
I will send them first thing tomorrow, and explain the location. Thanks for helping.
  • Nov 19, 2020 5:01 PM UTC
Ingen årsag :-)
  • Nov 20, 2020 7:08 AM UTC
Here is a coordinate: y: 97827,00 x: 144881,00. It is in Western sealand in Denmark near Hashøj fjernvarmeværk.
  • Nov 20, 2020 8:12 AM UTC
If that point is plotted as -144881, 97827 and reprojected that would take you to this location, so that's just multiplying the x by -1
Capture
  • Nov 20, 2020 9:02 AM UTC
Perfect, thanks a million!
