AttributeManager somewhat unexpected functionality
  • May 18, 2017 12:13 PM UTC
  • 89 views
Folks,
This is part observation and part confirmation of the general functionality of Transformers.
I have an AttributeManager. Amongst it's operations there is a conditional evaluation of a value.
If owner = XCOM then id = 0. This modified the id value. This was working. Then "all of a sudden" it stopped working.
During my manipulations I applied another modification to the owner field in the same AttributeManager.
If owner = XCOM then owner = Xcom. This modified the owner field. A case modification for the purposes of output.
What I didn't anticipate was that my earlier condition would stop working because the case of the owner had changed based on another condition.
I presumed that all operations in an AttributeManager operated on the original input file values.
Is this expected functionality?
Best answer by mark_f
Expected functionality
There is the option to define order
  • May 18, 2017 1:31 PM UTC
itay
Forum|alt.badge.img+19
  • May 18, 2017 1:32 PM UTC
Hi @andyew,
The order of the operations is important in the AttributeManager so if your second operation comes before the first one ( what doesnt make sense I realized while typing...) then the behavior is to be expected.
  • May 18, 2017 1:33 PM UTC
tricky to get head around when first arrived :)
gio
Forum|alt.badge.img+15
  • May 18, 2017 4:22 PM UTC
the order in a attribute creator is important in 2015, 2016 as well. When you are using attributes manipulated in a prior rule it will effect subsequent use in same attribute creator. Like chaining them.
