AttributeManager
  • Jul 16, 2021 11:41 AM UTC
  • 5 replies
  • 134 views
Hello everyone I got a little lost in this problem, I have three columns segment, direction.
I would like to obtain another order column which will be incremented in the event that we have a change either on the segments or on the direction, I tried to give you an example which explains the situation, thank you in advancequestion
Best answer by redgeographics
This is how I've solved it:
  1. Use an AttributeCreator to create an attribute "order" and set its value to 1
  2. Set up the AttributeManager with the Advanced Attribute Handling to look at the attributes of the previous feature.
  3. Set up a Conditional Value for the attribute order: if the value of Section or Direction of the previous feature is different to the one on the current feature the value for order on this attribute is 1 more than on the previous feature.
Screenshot 2021-07-16 at 14.58.28Hope this helps!
Forum|alt.badge.img+63
jkr_wrk
Forum|alt.badge.img+37
  • Jul 16, 2021 1:05 PM UTC
You can set the AttributeCreator to Advanced: Enable Adjacent Feature Attributes 1 Prior Feature.
Then create an Order attribute and fill it depending on a Conditional Value.
The condition is:
If feature[-1].section = section and feature[-1].direction = direction Then feature[-1].order else feature[-1].order+1
You have to set the default value correct because the first feature can't be evaluated.
If you have trouble setting this up, please apply a screenshot of your workbench/transformer settings so I can see what goes wrong.
thank you very much, i didn't pay attention
jkr_wrk
  • Jul 16, 2021 1:14 PM UTC
Did not see your reaction when i posted. Just curious, why use an AttributeManager?
It is rarely my preference to use the AttributeManager, but maybe I should change my mind.
  • I like to see where attributes are removed, filled, keeped or renamed so I tend to use these more.
The condition is:
thanks it work
