AttributejSONPacker and AttributeKeeper problem
i am using attributejsonpacker to pack some attributes and getting the packed attributes in writer but if i am using attribute keeper for some other attributes then i am not able to write packed attributes.
How can i add "_packed" attribute in attribute keeper also?
Best answer by david_r
You'll have to manually add the "_packed" attribute to the AttributeKeeper:
If the "_packed" attribute isn't selectable in your AttributeKeeper, you can insert an AttributeExposer just before and type in the attribute name manually:
  • October 12, 2017
  • October 12, 2017
Thanks a lot @david_r, it works :-)
