AttributeFilter is stopping all features in BATCH mode but works well in Workbench. What could be a reason for this ...
  • Oct 8, 2021 5:23 PM UTC
  • 54 views
mhab
Forum|alt.badge.img+10
I run features through an AttributeFilter Transformer in order to split the stream for specific manipulations downstream. If I test this in Workbench everything works as expected. If I call the workspace in BATCH from a DOS script all features end at the AttributeFilter (identical data).
In FME Log of the BATCH run I see lines like
AttributeFilter_9 AX31001 Transformer Output Nuker (TeeFactory): Cloned 818 input feature(s) into 0 output feature(s)
AttributeFilter_9 SD41000 Transformer Output Nuker (TeeFactory): Cloned 1154 input feature(s) into 0 output feature(s)
What is going on here ? Why are the features not passed ... very,very confused 👿 😮
FME 2021.0 up to 2021.1.3 all the same
mhab
  • Oct 9, 2021 8:32 PM UTC
It seems a VariableRetriever somewhere downstream is causing this weird behaviour.
I disabled and bypassed it and everything works as expected.
