AttributeCreator FindString to find the last occurrence of a string
  • October 24, 2016
  • 134 views
Hello, I have a full StreetAddress field and separate City/State/Zip fields. I want to parse Street only out from the StreetAddress field. I used AttributeCreator, Left() and FindString(). Please see below. Most records were correctly parsed out except for few ones like the second record in the table below. Is there a way for FindString() to return the last occurrence of a string? or any other ways for this purpose?
@Left(@Value(StreetAddress),@FindString(@Value(StreetAddress), @Value(City)) + 1)
StreetAddressCityStateZip1 Google Way Mountain View, CA 12345Mountain ViewCA12345
1 Houston Road Houston, TX 23456HoustonTX23456
todd_davis
Forum|alt.badge.img+23
  • October 24, 2016
Just basing this off what you have shown here, so not sure what all your data looks like.
Why don't you stringconcatenate: (this would be what it looks like in the bottom window) start off with a space ), @Value(CA) @Value(Zip).
Now you could just use the attribute created in the stringreplacer and replace on the streetaddress, replace with a blank.
This will avoid the issue you are having with a single attribute like Houston, not being unique in the entire string.
  • October 25, 2016
thanks. StringContatenator works.
