Attribute renamer
  • January 7, 2014
  • 77 views
Hi
I am looking  for some information on the attribute renamer and possibly some help tips on how to set up the parmeters to normalize addresses to a new schema.
Pat
  • January 7, 2014
could you perhaps give us an example input value and specify how you would like the result to look?
David
  • January 7, 2014
Hi David,
sorry for being vauge. I have several counties all with differing adress attributes(schema) that I would like to normalize into a new schema.
For example one may have the houise number prefix under "HSNP" and another has house number prefix under  under "prefix" and I would like them all to be placed under the new attribute off "AddNumPrefix".
There are also attributes with Address number street type unit type Zip code etc...
I am a student working on an address normalization project and am a bit overwhelmed.
Any guidance would be much appriciated.
Thanks
Pat
  • January 8, 2014
it sounds like the SchemaMapper would be more suited to that kind of mapping.
Also take a look at this FMEpedia article about the SchemaMapper.
David
  • January 8, 2014
Thank you David,
I will surely have a look.
Best
Pat
