Attribute Hider
  • Nov 6, 2017 7:48 PM UTC
  • 6 replies
  • 351 views
Does FME have a transformer for "hiding", as opposed to "removing" an attribute? I am using the FeatureReader to dynamically read a feature class that is specified by parameter. This script is then called for many feature classes. The attributes of any one feature class are thus not exposed.
However, for some features I need to access the ID field of the feature class, for example, "FID". I do this by an AttributeExposer in a custom transformer that is only called for a particular feature class.
But I don't want the ID field to carry on as an attribute when it is time to write the feature class to the output table. It would be great if I could then "un-expose", or "hide" the attribute, back to the level of visibility it had when I used the feature reader. Is it possible?
Best answer by jdh
You can hide an attribute using a quirk in the pythonCaller, there is a parameter for attributes to hide.
That said, if you are writing a table dynamically, then it's the schema that controls whether or not an attribute is included, not whether it is visible on the canvas or not.
erik_jan
Forum|alt.badge.img+26
  • Nov 6, 2017 7:51 PM UTC
Hiding an attribute will not keep it from being written.
For that you will need an AttributeRemover or AttributeKeeper transformer.
jdh
Forum|alt.badge.img+41
  • Nov 6, 2017 7:55 PM UTC
It is not a dynamic writer though, only a dynamic reader. The script is writing errors into an error table. For generic errors I don't need the ID field, but for errors specific to a given feature class, say, sewer pipes, I do need that ID field. Hiding it just keeps the noise down.
erik_jan
  • Nov 6, 2017 8:01 PM UTC
I see. In that case it makes sense!
  • Nov 10, 2017 4:20 PM UTC
I had to look at this one twice, and actually it does work. My only concern is that it works because of a 'quirk' in the PythonCaller, as @jdh described it. Someday that quirk might go away. I think it would be better to have an "attributehider" transformer that explicitly does the same thing.
jdh
  • Nov 10, 2017 5:02 PM UTC
It's a "quirk" in that I cannot think of a reason why the pythonCaller would have attributes that need to be hidden rather than exposed.
You can however vote on Takashi's idea on the subject. https://knowledge.safe.com/idea/27259/add-attributeslists-to-hide-option-to-the-attribut.html
Or mine: https://knowledge.safe.com/idea/19546/attributehider.html
