Atomise records
  • January 8, 2014
  • 67 views
I have a set of records (no attached geometry) which contain a lower and higher value in addition to several other attributes (see example 1), I want to atomise and split each individual record so that a new incremental record (+1) is created based on the lower and higher range value.  When each new record has been created, I need to move on to the next individual record and repeat (see example 2).
Example 1 Input
Attr1,Attr2,Lower,Higher
AA,1100,10,13
AA,1200,201,205
BC,2000,31,32
Example 2 Output
AA,1100,10
AA,1100,11
AA,1100,12
AA,1100,13
AA,1200,201
AA,1200,202
AA,1200,203
AA,1200,204
AA,1200,205
BC,2000,31
BC,2000,32
Please note that the data does not currently exist as a list which can be exploded.
Can anyone suggest a method to do this?
Thanks,
Rob
  • January 8, 2014
Hi Rob,
I think the Cloner transformer could be a solution. Use a Cloner to create copy features, the number of copies should be "Higher - Lower + 1" for every input feature. Each copied features will have an attribute named "_copynum" (by default), which contains 0-based sequential number. You can then calculate "Output" value as "Lower + _copynum" using an ExpressionEvaluator or an AttributeCreator.
Hope this helps.
Takashi
  • January 8, 2014
Hi Takashi,
Easy when you know how!
Many thanks that has worked a treat, just what i wanted.
Best wishes,
Rob
