AreaBuilder vs ArcGIS Pro's Feature to Polygon
  • Nov 16, 2020 4:22 PM UTC
  • 78 views
Is there a way to get AreaBuilder to produce results closer to Pro's geoprocessing? It seems that whenever I give FME lines similar to the example below, it builds one polygon and calls it a day unless I specify an absurdly high snapping tolerance, in which case it produces garbage (e. g. a 1m tolerance would create a small extra triangle in the middle of the northern line where the small /\\ is, but still leave the large area empty; 5m would create a large jaggy polygon. The example is roughly 100m across, btw.). The polygon parameters have no effect, neither do the snapping types. The lines are 2D, I've also included a 2DForcer before the AreaBuilder to make 100% sure it doesn't even get Z coordinates, but to no effect.
Pro, with all of the line vertices displayed and filled areas (three separate polygons, as expected):
pro_area_verticesFME, with one polygon ☹
fme_area
dustin
Forum|alt.badge.img+36
  • Nov 16, 2020 4:31 PM UTC
When I have situations like this, I normally run the lines through an Intersector first, and get better results.
Intersector unfortunately didn't help, but I got it to work applying the idea using a chopper to extract all vertices, then using a PointOnLineOverlayer with 0.01 tolerance, then the AreaBuilder with Endpoint snapping tolerance at 0.01 as well.
fme_area_v02
