ArcEstimator
  • Mar 14, 2016 6:02 PM UTC
  • 42 views
I am trying to convert SDE geodatabase polygon to an AutoCAD DWG. I want true arcs in the DWG. I am using the ArcEstimator but am getting the following error...
ArcEstimator: Cannot convert line with bad geometry to an arc representation
Is there something I need to do to my polygon feature class before running the ArcEstimator?
Thank you
mark2atsafe
Forum|alt.badge.img+59
I don't know that the transformer will work on polygons. Maybe you could convert it to a line first with the GeometryCoercer?
