AnchoredSnapper
  • Jun 24, 2021 10:05 AM UTC
  • 6 replies
  • 106 views
Hello everyone, I need your help with AnchoredSnapper, basically I have two vector layers:
- linear layer which is in the form of a road network.
- point layer (Camera positions).
I would like to attach these camera points to the road network, what I have problems with is the areas where we have road intersections, I don't know how to configure it so that it snaps the points to the right segments, if you go to the image link, i tried to show you that the last point is attached to the correct segment, but in reality it is going to be snapped on the other segment which is closer to it. So if you have any answers, I'm interested, and thank you
link image: https://zupimages.net/viewer.php?id=21/25/2nrm.png
  • Jun 24, 2021 10:28 AM UTC
If your camera points have an attribute indicating the road ID (and your road geometries have the same ID in an attribute of the same name), you can use this as a Group By to prevent your camera points to snap to any other road geometries.
  • Jun 24, 2021 10:35 AM UTC
firstly, thanks for your reply
unfortunately no I don't have any fields indicating a route ID in the camera position layer
Forum|alt.badge.img+54
  • Jun 24, 2021 10:45 AM UTC
How is it determined that the horizontal road is the one the camera should be snapped to? You need to be able to define some sort of rule, whether that is angle, distance or something else.
  • Jun 24, 2021 10:50 AM UTC
yes absolutely, that's the objective, but currently I can't imagine this rule.
geomancer
Forum|alt.badge.img+71
  • Jun 24, 2021 11:51 AM UTC
So, maybe there is a part of an attribute of the camera's that you can relate to the roads (e.g. all camera's that start with 1 stand along road A)?
Or maybe the camera's are numbered in a certain way, and you can determine camera's 101-199 stand along road B, and camera's 201-299 stand along road C?
Or maybe there is an external source that links camera ID's to roads?
Or maybe you can find out which roads have camera's, and which roads do not?
Or maybe something completely different...
You will have to look closely at all the information that is available to you, and maybe you will need to get extra information.
  • Jun 24, 2021 12:56 PM UTC
Hello, good for the layer of the cameras they do not have an attribute which can inform us on the route, there is only one attribute "name" which indicates to us from which video, the image is extracted, in all case i will see what i can do, thanks
