anchored snapper ( problem)
  • Jul 8, 2021 7:59 AM UTC
  • 46 views
Hello everybody,
If you have seen the image, the labels displayed near the points they mention the order or the route of GPS, I would like to know is there a possibility for example to eliminate the segment which is near point 70, because in real life it should snap on the other segment.
Capture_community
https://zupimages.net/viewer.php?id=21/27/j24o.png
panda
Forum|alt.badge.img+20
  • Nov 3, 2021 10:03 PM UTC
Maybe you can buffer point#70 so it's big enough to overlapped the unwanted segment and run spatial filter or spatial relator and filter that segment out.
