Amazon Athena Package v1.0.0 Issues
  • Jun 28, 2021 3:43 AM UTC
  • 36 views
jbradfor
Forum|alt.badge.img+7
After we upgraded to v1.0.0 we starting getting a ton of datatype errors.
The Athena Query was working fine and writing results but the connector was choking on such things as decimal to int casts, and some random strange errors on cols we have never had issues with before. I started to resolve some of them by switching to bigint, but then another one in the stream would fail. Ugh.
We have close to 75 Athena Mappings, so we reverted back to the previous version. Solved everything. If we had not, we would have to modify things like casts and decipher some other strange errors on many of those 75 mappngs.
Anyone else having issues with v1.0.0?
Hi @jbradfor​
Would you be able to submit a support case and if you're able to, provide us with a reproduction workspace and data? We can then investigate and try and get this fixed for you.
What version were you on where you weren't experiencing any issues?
