All Transformers lost
  • June 30, 2015
  • 52 views
Hello
After closing my FME workbench all transformers and annotations were lost.
All Reader and Writers are renamed und start with a $-character.
Is there anybody who can tell me what happened here and how to avoid this in the future.
And even more important: is there a way to reconstruct the workbench
I work with FME-Desktop  2014.
  • June 30, 2015
Hi
Unfortunately, I've seen the same thing happen a couple of times when uploading/downloading workspaces to FME Server where the version of FME Desktop didn't match the version of FME Server.
I suggest you send your workspace file to Safe support (https://safecommunity.force.com/knowledgeSubmitCase) together with a description of what happened.
David
  • July 1, 2015
Thanks David
I will do so. In the meantime I found out, that this phenomen occurs when I copy a group of transformers from another workbench into mine. once this change is saved and the workbench closed, theres no way to reopen it. There may be a version conflict in here too, because we have both FME Desktop 2014 and 2015.1 installed and it's possible that either of the in volved workbenches was openend (not saved) with the newer version while we use V2014 as working software
Urs
