AIXM 5.1 failing to write Elevated point
  • Aug 29, 2023 2:14 PM UTC
  • 55 views
I've used the Airport demo as a base and all features are connected properly in the output file except that the point feature is missing. I've attached the image below where you can see that the gml_object_name is populated just like in the demo. I've tested all posibilities in the demo and reduced the attributes to gml_id and gml_parent_id just to remove any other possibilities.
Could you tell me why is this happening? What is expected for the ElevatedPoint to be added?
Thanks
kailinatsafe
Forum|alt.badge.img+24
Hello @mrdado12345​, thanks for posting. Is this the demo you're currently working off of? If not, please let me know the correct tutorial and I will happily take a look. It may be helpful to know which version of FME Form you're using (Help > About FME Workbench), and which part/step/bookmark of the workspace you're having issues with (if possible). Best, Kailin.
